Hi Guys
Need a little advice. Where Im at AC voltage id suppose to be 230v
Problem the highest that I've measure is 228.6 most of the time it
averages around 226 or so. Believe or not when voltage goes down
to around 220-221 like now, music sounds slow & fat. It's only a
difference of 5-8 volts & yet SQ is so much different.
Question what can I do to bring up the Voltage ? With a variac will
SQ be affected ? Im using a 100 watt AB amp, ML speakers with
a dac & an SD card player. With this set up, if a variac works,
what va ratings should I be looking for ?
Thks Guys
Thks Guys
Anything over 200VA would be fine.
This should be ok. Welcome to NextWarehouse.com
2000W 230V Power Conditioner Automatic Voltage Regulation AVR AC Surge Protection 6 Outlets UNIPLUGINT Adapter (LR2000) | Tripp Lite
Is that not what a computer UPS does ?
With a UPS, there is always the battery problem.
what about SQ does the triplite
brings with it other draw backs ?
All these units work in similar ways, so try an inexpensive one and see.
Using a Variac for this situation is problematic at best, and risks damaging your equipment.
I find it hard to believe that a competent SMPS has such poor output voltage stability. The spec says it can operate from 200-240V in. Ah, just noticed that output voltage varies with input voltage; in fact the output voltage is slightly more variable than the input! Very strange. Maybe you need a better PSU?
A UPS is the way to go. The battery problem is when there are power outages, this is what wears them, and they are pricy.
Get an UPS that runs on 12volt, then any car battery will do. Only small ups run on 12v. Large ones are likely on 24v, some more.
The 12v battery car on a small UPS, I have used, no problem, you even have a fresh charged battery ready to jump start your car.
- Power Supplies
- AC Voltage Stabilizer
