PL504 circuits.
I have some PL504's. Except for some mention that these could be used in an OTL, I couldn't find any circuits on the web.
Would anyone be able to suggest the best application for this tube. Are there any published circuits for an OTL using these tubes?
Thanks,
Ashok.
zygibajt said:
Braun CSV-60 used those tubes.
My friend has one,made in 1957.Sounds quite good.
It is push-pull design,just one pair for each channel.
As I recall ECC83 is a driver tube.
I think I have PDF with schematics of this amp.
Bartek
There must be some mistake. The PL504 didn't appear until 1965. I can still remember my first sighting of one in 1966 :bigeyes:
Hello ,
Klein und Hummel had many amps with this tubes , first they use EL 36 , then came EL 500 ( PL 500 ) , EL 504 in the same circuit .
The EL 36 version is the K +H VS 70 , the VS 71 is the newer one with EL 504 .
Also their studio mono amps V 30 were build with EL 504 , in all these amps the driver tube was ECF 80 with the triode as phase inverter .
There were also amps from Telefunken , PE and Elac with EL 504 in the sixties .
I think , I have all these circuits , send me an E - Mail .
Regards , Alex .
