diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Analogue Source (http://www.diyaudio.com/forums/analogue-source/)
-   -   Do electrolytes dream of ceramic caps? (http://www.diyaudio.com/forums/analogue-source/29856-electrolytes-dream-ceramic-caps.html)
borges 9th March 2004 07:59 AM
What's the status on good decoupling electrolytes these days? Is there still a need for ceramics and 'lytts in paralell?
What I'm decoupling are CS8414 s/pdif receiver, PCM1704 and PCM1794 DACs, and opamps like 2134/2227/5534/2604.
The perfect decoupling, I guess, would be a cheap and compact SMD 'lytt that goes well into the MHz range. Any personal experiences you care to share with me on this one?
Greetings,
BÝrge
cabbagerat 9th March 2004 08:30 AM
The CS8414 datasheet specifies an electrolytic and a ceramic in parallel for decoupling.
borges 9th March 2004 10:19 AM
I know, but why is the ceramic specified in the first place? If the electrolyte alone is able to produce high-frequency supply current at a low impedance, is there a need for the ceramic at all?
One good electrolyte means less routing and thus less parasitic inductance between decoupling and power pin.
EC8010 11th March 2004 09:46 PM
All capacitors have series inductance causing them to have a rising impedance above their self-resonant frequency. Unfortunately, an electrolytic's resonant frequency could be as low as a few tens of kilohertz. Bypassing the electrolytic with another capacitor is the traditional method of more nearly approximating to an ideal capacitor. Ceramic capacitors are usually specified by (American) IC manufacturers because the USA has a large ceramic capacitor industry. Plastic capacitors are equally useable as bypasses.
Christer 11th March 2004 10:09 PM
This thread may be of some interest:
http://www.diyaudio.com/forums/showt...5&pagenumber=1
Fred Dieckmann 11th March 2004 10:58 PM
Most ludicrous post of the week?
"Ceramic capacitors are usually specified by (American) IC manufacturers because the USA has a large ceramic capacitor industry. Plastic capacitors are equally useable as bypasses. "
Do you really believe this? Does this include decoupling for digital circuits? Doesn't the US make film caps as well, and the Japanese ceramics? Are you just trying to be funny or are you really that confused? I think 20 minutes with a search engine could help you learn the difference between ceramic and film caps........ it might be time well spent. I will even give you a big head start.
http://www.faradnet.com/
Raka 12th March 2004 06:37 AM
Re: Most ludicrous post of the week?
You are so kind, Fred... I like your emails a lot.
BTW, thanks for the link, it's a interesting source.
EC8010 12th March 2004 10:59 AM
Fred, if you disagree with a post, it is sufficient simply to give reasons why. Personal abuse is unnecessary.
The source of information that led to my remark was:
"There is an interesting geographical factor involved, though. US manufacturers are stronger in ceramics than in film, whereas in Europe the situation is reversed. Therefore, US design engineers will go for film. So far so good, but the majority of digital ICs sold throughout the world are of US manufacture, and their application notes are written by US applications engineers. These, quite naturally, specify ceramic capacitors when it comes to recommended practice for IC decoupling. As a result, the suppliers of monolithic ceramics are riding on the back of an enormous hidden subsidy as designers worldwide take the easy route of sticking recommended parts in their circuit designs."
This quote was taken from a discussion of ceramic versus film capacitors on p79 of: "The Circuit Designer's Companion" Tim Williams. Butterworth-Heinemann. (1991) ISBN 0 7506 1756 X
Havoc 12th March 2004 11:22 AM
Well, while film is indeed usable as decoupling, it will never be as cheap, nor as small. And since decoupling caps are a large portion of any pcb -in count and space- it makes sense to use the cheapest/smallest that do the job.
EC8010 12th March 2004 11:41 AM
Agreed, on all counts.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
