I'm building my first class A amp, the Zen IV, and am presently putting the power supply together. I want to look at the regulated power supply and see how much noise is actually there. I've got a Tek 2445 scope, however I can't deny I'm a little nervous about connecting it up to the power supply. I have no real basis for this fear, I just need someone to say, "Go ahead, hook up the scope, you won't fry it!" Thank you in advance for assuaging my irrational fears. On the off chance that my nervousness is valid, I'd appreciate knowing that too!
Dave
Dave
take a look at the several application notes at Linear Technology on noise measurement. They are sprinkled through LLTC's literature -- App Note 70 comes to mind -- although it deals with switching regulators there is an appendix devoted to noise measurement.
to measure noise, you really have to measure it within a known bandwidth -- that's why some of the old TEK 5XXX series scope plugins (like the 5A22N differential amplifier) are so wonderful -- you can set them up for 10Hz to 10kHz bandwidth, and the scope was designed for measurements just like this in automotive and medical technology. The 5A22N measures down to 10uV/cm and as high as 50V/cm. There have also been designs in recent issues of AudioXpress for a low noise measurement preamplifer.
FWIW, I routinely use my scope on tube equipment, with about 10 times higher voltages. To see what's going on with the power supply, just use the AC coupling for the input.
One other fun trick I've mentioned before is to connect a cap between the supply rail and a headphone amp. Play music or test tones through the amp and listen through headphones- you'll hear for yourself what's on the rail besides DC.
Netlist said:Hi Dave
Are you and your scope still alive?
/Hugo
Well, I'm fine. My scope, however, is not.
I'm not exactly sure what happened, but when I connected it up there was a nice pop, and the scope now seems to be dead. So... that didn't turn out quite as I had hoped! Ahh well, I'm sure I'll get it back working soon enough.
Dave
Dave
You "needed" a differential probe -- there was probably a differential between the "ground" of the scope probe and the "ground" of the device under test -- we all learn this the hard way.
So how hard of a lesson is this? Do you know what's wrong with the scope, and how to fix it? Thanks for the information, btw.
Well, this is one of those times where you feel silly, and yet don't mind. I finally got some time to look at what happened and was grateful to find that my power bar became a sacrificial lamb, paying the penalty for my ignorance and saving the scope. I must admit I've never seen a power bar completely fry out before, but I'd rather it be that than my scope!
- power supply noise
