Mr. Pass I have just come across a Forte Model 6a. I think it is 200wpc and uses IGBT's.
Can I reduce the rails by half (by rewiring the Toroids in series) and bias it to 50 watts class-A?
I have done it in the Forte Model 3 with good results but that uses BJT's, I am worried playing with these IGBT's.
If so, what idle bias do you recommend going to with rails of approx +/-38vdc?
Thanks much in advance,
K-amps.
K-amps.
Rule of thumb:
To stay in the same thermal envelope: When halving the PSU voltage, you can double the current.
The other alternative is to aim for a temperature which should not be more than 70 degC.
You might also want to do some reading up on IGBT's to evaluate their thermal stability. If I know NP, I suspect that the emitter resistors are large enough to offset any thermal runaway should the devices be so inclined.
Petter
Petter
Thanks Petter,
Additionally I'd like more insights especially from NP. I suspect he knows something about this that I should know.
I just dont want to blow the IGBT's and have a worthless amp on my hands.
I agree with you on the value of NP's emitter resisters, probably a minimum of 0.47 ohms... right?
K-amps said:Mr. Pass I have just come across a Forte Model 6a. I think it is 200wpc and uses IGBT's.
If so, what idle bias do you recommend going to with rails of approx +/-38vdc?K-amps.
Should work just fine, although I don't have a schematic on
it, as it was after my time. I would just crank up the bias until
the sinks reach a continuous 50 deg C (touchable for 5 seconds).
- Question for the One and Only. (Mr. Pass)
