Connect Virtual Ground to Real Ground
Dear All:
I am using a cmoy design amplifier using a voltage divider to create a "virtual ground" (8v/2) = 4v.
Is there a problem if i connect the virtual ground (4v) of the amplifier to a real ground in the analog source?
For example if I connect a jack to my computer headphone output there will be a difference of 4v between the "virtual ground 4v" vs the real ground of my computer jack connector.
I'm confused.
Regard.
Alfredo Mendiola Loyola
Lima, Peru
Every voltage is the difference in potential between two places. No one place has a voltage. So you need to ask yourself: with respect to what is the virtual ground at 4V? Another question is: what is the voltage at one terminal of a battery?
I'm using a 8 volts power supply, but I can replace that power supply by an 8v battery.
+4v (8v with respect to 4v)
-4v (0v with respect to 4v)
Regards.
Alfredo
