Apologies if I should have posted this in the power supply forum. I'm building an amplifier and I'd like to use one EI transformer per channel. I realize I should orient the "bells" away from the circuit boards but what about the orientation of the two transformers with each other? Does it matter or is there a minimum distance I should keep between them? They're only 90VA apiece. Should I "stagger them" so their bells aren't pointing right at each other?
mains power transformers should be positioned to minimize mag field leakage coupling to the rest of the amplifier circuit
but mag field leakage coupling between the power xmfrs is not an issue - they both connect to the power line so are already heavily coupled, the mag field leakage coupling between them is orders of magnitude less
audio output xfmrs may have numerically measurable coupling that some may want to minimize but stereo channel crosstalk < -40 dB is not a big deal for listening with speakers
Hello jcx,mains power transformers should be positioned to minimize mag field leakage coupling to the rest of the amplifier circuit...
Does this apply for toroidal transformers as well? Thanks.
again - totally depends on what the xfmrs are doing - when connected to the power line there is no reason to be concerned about coupling of leakage mag field between the 2 power line xfmr - their primaries are Wired Together
if anything you would want to see if some orientation of the power transformers could make the sum of their external leakage fields cancel somewhat - that won't be by placing them at 90 degrees to each other
The circuits around the EI transformer can be susceptible to the spray of radiation.
Often rotating the Mains transformer can effect a big change in hum measured on the output of the circuit.
If you have many circuits spread around the floor of a chassis containing an EI transformer, it may be difficult to find an optimum orientation for all the circuits.
Toroids leak much less radiation, but they too can benefit from rotating for least interference.
I would expect Ccore and Rcore and other "exposed core" transformers to be noticeably worse than toroids.
Replacing the solid core tails fitted as standard to many transformers, with stranded wires allow experimentation to minimise interference.
External field cancellation is almost impossible .... crosstalk or cross induction can be reduced ... ( in transformer language it is known as coupling factor ).... this is the purpose of 90 degre mounting orientation.
read the 1st post: it appears that the subject is dual Power Line Connected transformers - the 90 degree minimum mutual leakage field coupling condition is irrelevant to this application
minimum mutual coupling is only important for Signal transformers carrying independent signals
the situations are different - the application changes the weighting of which engineering principles are important
- EI Transformer Question
