R16 to be precise.
Was measuring the two caps C11 and C9 and C11 I could get close to 175V but the other would shoot up to over 350V (brought up via Variac).
I swapped the 5842's around and it stayed with the channel so it seems not to be the tubes.
R16 then smoked so I shut down.
Any advice? What could cause 350V at C9?
I should add that B+ and B- are within expected range.
Sorry, I thought I had mentioned it was the TSE I was building.
JP; thanks, I have ordered a replacement as I thought that might be a culprit.
Jon, checked the resistors match the Part List.
Being doing some measurements comparing resistance across resistors and they seem to match on both sides (R16 slightly off now that it smoked).
I'll start by replacing the 10M45 and see how that pans out.
Won't make that mistake again.....hopefully!
Ohh but you will - I've done if more than I like to admit.
But then you develop a habit to look for that sort of thing first
Most diy-ers transition from 'that part must be broken' to 'what could I have possibly have done wrong here' within a couple of years
Jan
LOL
Well the parts are replaced but now I am getting weird numbers from B+ and B- and they are on runaway.
I need to spend some time checking through the changes I made and then I'll start a new thread if I cannot resolve the issues. Be a couple of weeks though before I can get to it.
Thanks for all your help everyone.
So managed to get B+ and B- in check but when measuring C9 to ground and C11 to ground (with rectifier and the 5842's in place) I am getting runaway high voltages where I should expect to get something around 175Vdc.
Up till that point the checkout was going to plan.
Suggestions on what to check are welcomed.
Thanks.
Thanks.
- More Vendors...
- Tubelab
- The smell of resistors in the evening
