diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   Has anyone heard these Fritz Fostex builds? (http://www.diyaudio.com/forums/full-range/254471-heard-fritz-fostex-builds.html)
wendelltate 10th April 2014 09:45 PM
I was searching around for full range bookshelf/stand builds and ran into these. 8inchFullRangeSpecs
A friend of mine has a pair of Fritz's speakers and really likes them a lot. I was wondering if it would be worth it to try to create these...
Scottmoose 10th April 2014 10:01 PM
As far as I am aware they are just straightforward reflex boxes of the same volume & tuning Fostex suggested in their plan sheets, albeit with the HxWxD dimensions slightly altered. In many cases, you'll likely do better with different volumes & tunings -Fostex's BR designs can be (not invariable) somewhat idiosyncratic, at least by Western lights.
Note that all of the drivers referred to are defunct. The FExx7E series was discontinued, while the FExx6E series was replaced by the current FExx6En series. The higher Q drivers Fostex currently produce, which are more suitable for reflex loading than the En series drivers, are the FFxx5WK models.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
