Enclosures, headphone amps, stands, switch box, crossfeed... special offers
Special prices on the amplifiers, headphone stands and wood-aluminum enclosures currently in stock.
My regularly updated list: *** Special Offers *** | mfspdesigns
Presently available:
Prices don’t include shipping costs.
Other products and options available… Don’t hesitate to contact me for any other information. Worldwide shipping.
*New*: Crossfeed filter (VCF1) (104.95 EUR)An externally hosted image should be here but it was not working when we last tested it.
*New*: Passive Switch Box TRS 1/4" (PSB2-1) 2 inputs, 1 output (can also be used as 1 input, 2 outputs) (Price from: 24.90 EUR). Full kits with cables are also available. More information and detailed prices here.An externally hosted image should be here but it was not working when we last tested it.
Headphone stand (WW01250WAL)walnut (29.95 EUR)An externally hosted image should be here but it was not working when we last tested it.
RCA interconnect cable (High quality Klotz professional cable with Neutrik RCA gold plated connectors). Special Prices from (for 1 set of 2 cables): (1m): 19.90 EUR | other cables and other lengths avalaible.An externally hosted image should be here but it was not working when we last tested it.
M^3 headphone amp (mahogany enclosure) with Sigma11 (24,3V) AD8610. Possible options: Epsilon12, variable Gain 2-17 or Bass boost. (549 EUR)An externally hosted image should be here but it was not working when we last tested it.
CK²III Cavalli Kan Kumisa headphone amp. Possible options: Epsilon 12, Pre-amp, crossfeed. (349 EUR)An externally hosted image should be here but it was not working when we last tested it.
Headphone stand (AW02280MAH) mahogany or walnut (89 EUR)An externally hosted image should be here but it was not working when we last tested it.
Headphone stands (AW01280MAH) mahogany or walnut (69 EUR)An externally hosted image should be here but it was not working when we last tested it.
Wood and aluminum Enclosure (EWA02WAL) glossy walnut (internal dimensions (mm) : 164(width)x244(depth)x46(height) (89 EUR)An externally hosted image should be here but it was not working when we last tested it.
Wood and aluminum Enclosure (EWA01WAL) glossy walnut (internal dimensions (mm) : 270(width)x200(depth)x46(height) ) (99 EUR)Prices don’t include shipping costs.
Variable Crossfeed Filter
I've just updated my list in the first post with some new products including a Variable Passive Crossfeed Filter.
Variable Passive Crossfeed Filter using the Meier natural crossfeed circuit (used in the Corda Cross-1). As per the designer of the circuit ” this filter mimics aspects of directional hearing and strongly improves on the soundstage as produced by headphones. Listening thus becomes more natural and relaxed.”
The VCF1 features only high quality components:
Thank you for looking!
- 3 levels of crossfeed (low, medium, high) selected by the central rotary switch
- Toggle switch to bypass the crossfeed filter for conventional stereo listening.
- 6 levels of low frequency response selected by the rotary switch on the left
- 6 levels of high frequency response selected by the rotary switch on the right
- VISHAY DALE RN55D series Resistors
- VISHAY polypropilene (MKP419 and MKP416 series) Capacitors
- Rotary switches: 3x LORLIN with silver plated contacts, CK series
- Toggle switch: with silver plated contacts
- Neutrik-Rean gold plated RCA connectors NYS367 series
- Case: Black HAMMOND case (160mmx165mmx53mm) with 3x 22mm black anodised aluminum knobs
- Attenuation: 0 dB (stereo) | -2.2 dB (crossfeed on)
- Low freq. adjustment range: 3 dB
- High freq. adjustment range: 3 dB
