diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   Help! Anyone in Seattle area willing to take on a challenging F5T issue? (http://www.diyaudio.com/forums/pass-labs/245866-help-seattle-willing-challenging-f5t-issue.html)
SirByrd 13th November 2013 11:40 PM
I have a pair of F5T V2 monoblocks that I'm building, they are all assembled, but I am having issues with both amps in the amplifier section, power supply is working fine. Everything is wired up, and I've triple checked all component values and locations, polarities, all wiring arrangements.
Problem is that I'm getting .4V across the source resistors with only 20VAC going into the amp... P1,P2, and P3 do not change anything, DC on the output is about 1V with the same voltage in, power supply is about half the voltage it should be at 20VAC, but is fine when unloaded.
I don't think I have the right kind of brain for amplifier work and trouble shooting, so I want this to be the last amp I do, but that means it has to be finished first...
Anyway, I know some of you are more sadistic than I and would probably enjoy trouble shooting these, since it should be a pretty obvious solution that I'm just overlooking because I'm too dense.
Here's what we are dealing with.
Try not to give me too much **** about my wiring, it's only my second solid state amp :)
http://i.imgur.com/8hM4JdX.jpg
http://i.imgur.com/jrIjK1x.jpg
http://i.imgur.com/TUKnvsv.jpg
Don't have any money, but would be willing to help with a speaker project if there is anyone who can conquer this beast.
6L6 14th November 2013 12:27 AM
The wiring is actually very beautiful!
Where did you get the PCB?
6L6 14th November 2013 12:33 AM
I see that the bias thermistors (the 4.7K ones on the PCB) are mounted under the board. Are you sure they are not shorted?
vdi_nenna 14th November 2013 02:22 AM
Its possible the mosfets are too far from the PCB. Not saying that's the exact problem, but usually lead lengths go 3-5" max.
This might sound bad, but you are having the same exact problem on both sides, so its consistent.
Also, nothing burned up. That's a plus as well. You are half way there. Don't give up.
It probably a reversed component somewhere or a resistor value is too high.
Checking your wiring and component placement 2 or 3 time will cost nothing but time.
Check everything again with no power to amp.
KatieandDad 14th November 2013 03:38 AM
Carefully check your rectifier and its connections.
SirByrd 14th November 2013 04:14 AM
Quote:
Originally Posted by 6L6 (http://www.diyaudio.com/forums/pass-labs/245866-help-seattle-willing-challenging-f5t-issue-post3702825.html#post3702825)
I am sure they are not shorted unless the painted case is electrically conductive, I could space them off of the heat sink just in case, right now the leads are bent so that when I install the board there is a bit of spring tension from the leads to keep it in contact with the heatsink. What would happen if they were shorted?
Quote:
Originally Posted by vdi_nenna (http://www.diyaudio.com/forums/pass-labs/245866-help-seattle-willing-challenging-f5t-issue-post3702900.html#post3702900)
I really hope that's not the issue. If I really have to, I could mount all devices on the left heatsink using a heat spreader, no new holes needing to be drilled, but I would be wasting the right heatsink.
The leads are not as long as they look, the chassis is really tiny, they are at most 6", I knew I was pushing it when I did that, but with my boards there was no other option since all devices were on one board. Didn't know there were boards with separate N and P channel PCBs until it was too late.
I checked all of the component values and orientations against the silkscreening AND the schematic, everything is in the right place, is the right value, and is the right orientation. The output devices are all in the right place, and are the right polarity. None are shorted to ground from any pins.
Quote:
Originally Posted by KatieandDad (http://www.diyaudio.com/forums/pass-labs/245866-help-seattle-willing-challenging-f5t-issue-post3702958.html#post3702958)
I'll check them again.
I have operated the power supply independently from the amplifier board, and have a bit over 32V unloaded, don't remember exactly how much.
SirByrd 14th November 2013 04:26 AM
I think I figured it out!!!
I'm using the IRF9240/IR240 (I think, I'll double check those transistors) same transistors as many use in the F5, but the IRF 9240 is a P type and the FQA19N20 is an N type.
So it could be that the output transistors are in the wrong place, piece of cake, just need to resolder a couple of them, and remount two on the opposite side.
permaneder 14th November 2013 05:04 AM
Quote:
Originally Posted by SirByrd (http://www.diyaudio.com/forums/pass-labs/245866-help-seattle-willing-challenging-f5t-issue-post3702996.html#post3702996)
Just on other thing (which probably might not solve your issues yet): Solder the gate stopper resistors directly to the gates of the output MOSFETs to prevent the amp from HF oscillation. As far as visible on your photographs, you didn't.
SirByrd 14th November 2013 05:11 AM
Quote:
Originally Posted by permaneder (http://www.diyaudio.com/forums/pass-labs/245866-help-seattle-willing-challenging-f5t-issue-post3703016.html#post3703016)
R13 through 16?
permaneder 14th November 2013 05:17 AM
Quote:
Originally Posted by SirByrd (http://www.diyaudio.com/forums/pass-labs/245866-help-seattle-willing-challenging-f5t-issue-post3703018.html#post3703018)
R13 through 16?
Yes
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
