I would like to do a WT/MW center channel with two 10" woofer in 47 litter each, cut at 80hz
I simulate the ScanSpeak Discovery 26W but I have a bump between 60 and 200hz.
Not very good so I look the SB acoustic SB29 so if you have some driver thant can be used in a little sealed enclosure.
thanks
thanks
