diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Software Tools (http://www.diyaudio.com/forums/software-tools/)
-   -   Anyone know this crossover calculator? (http://www.diyaudio.com/forums/software-tools/237584-crossover-calculator.html)
Inscrutable 13th June 2013 10:36 AM
Anyone hear of - or better yet, try - this crossover component calculator? Wonder if it looks plausible and what kind of results to expect? Rather than springing right away for an active setup thinking I will try a passive 4th order Butterworth or L-R. Will be doing a front screen array of three two-ways incorporating a single 2226j woof and 2446h comp driver and 2385a horn. Thinking of crossing at 600 Hz.
any other thoughts, advice, schematics also more than welcome! I have made a lot of sawdust, but this is my first foray into solder fumes.
Passive Crossover Design Equations Formulas Calculator - Two Way Fourth Order Network Gaussian Linear Phase Butterworth Legendre
Inscrutable 15th June 2013 10:50 AM
I compared it to Erse, and for a LR24 they return exact same values EXCEPT one inductor in the tweeter is double the value.
Do I need a third calculator to break the tie?
Even with an L-pad I wouldn't have the range to make it up if I use the 'wrong' one. What would be the sonic effect of it being either too large or too small a value? This is the inductor closest to the driver.
Jsixis 22nd June 2013 09:31 PM
I'm not that smart but from reading about crossovers electronic is the way to go if you have the amps. Designing and getting a 4th order to work in the real world is expensive.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
