Got this amp for repair.
Powers up green then power LED flashes on and off red.
Music light is green.
Protetion light is amber or red.
There is no voltage on the gates of the IRFZ48 p/s fets.
There is no rail voltage coming from the rectifiers.
Pic#1 power supply
Pic#2 output stage
Any ideas?
Pic#1 power supply
Pic#2 output stage
Any ideas?
Do you have audio on pins 2 and 8 of IC401?
If you operate all of the other switches through their entire range, does audio ever play through the dead channel?
Im sorry Perry this amp is a MRV-1505. Same same? Still need the same info?
No these are 2 different amps. The original post was suppose be for a MRV-1505 but I screwed up and called it a MRV-1507.
When I made the post on the MRV-1507 (#3) somehow the seperate post became one post? I dont know?
The MRV-1505 has the issue with each channel working and not working when the 0/180 phase switch is switched and the MRV-1507 has the issues from post #3.
I asked a moderator to delete the posts, but they said they would have to delete the whole thread. So I figured we could just start from post #3 and focus on the MRV-1507.
Pic#1 power supply
Pic#2 output stage
Pic#1 power supply
Pic#2 output stage
I see 2 494's one says IC601 and one says IC605.
Shall I take readings from both?
Do I use the battery terminal or direct battery terminal or both when powering this amp?
When I power the amp its like it starts to power up drawing a few amps of current then drops to nothing on the meter of my supply.
IC601
1: 0.967
2: 0.963
3: 3.850
4: 0.221
5: 1.668
6: 1.670
7: 0.004
8: 14.53
9: 0.410
10: 0.427
11: 14.53
12: 14.53
13: 5.05
14: 5.05
15: 5.05
16: 0.004
IC605
1: 0.954
2: 0.952
3: 3.873
4: 0.220
5: 1.674
6: 3.762
7: 0.004
8: 14.53
9: 0.433
10: 0.428
11: 14.53
12: 14.53
13: 5.05
14: 5.05
15: 5.05
16: 0.003
1: 0.967
2: 0.963
3: 3.850
4: 0.221
5: 1.668
6: 1.670
7: 0.004
8: 14.53
9: 0.410
10: 0.427
11: 14.53
12: 14.53
13: 5.05
14: 5.05
15: 5.05
16: 0.004
IC605
1: 0.954
2: 0.952
3: 3.873
4: 0.220
5: 1.674
6: 3.762
7: 0.004
8: 14.53
9: 0.433
10: 0.428
11: 14.53
12: 14.53
13: 5.05
14: 5.05
15: 5.05
16: 0.003
- General Interest
- Car Audio
- Alpine MRV-1507
