diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Headphone Systems (http://www.diyaudio.com/forums/headphone-systems/)
-   -   Stax SRM-212 repair? (http://www.diyaudio.com/forums/headphone-systems/226077-stax-srm-212-repair.html)
randomlf 20th December 2012 01:08 AM
Just received this broken unit. Right channel works perfectly but left channel is cut out.
Do you have any suggestions what parts should I try to replace first?
Tried to search the web but couldn't find a service manual anywhere..
Here are pics for the amp:
http://imageshack.us/photo/my-images/9/stax0401.jpg/
http://imageshack.us/photo/my-images...ax0022225.jpg/
http://imageshack.us/photo/my-images...x33330401.jpg/
http://imageshack.us/photo/my-images...0022rr225.jpg/
randomlf 21st December 2012 10:33 PM
Any help would be appreciated, even if you don't have experience with this specific unit.
I don't understand anything about amplifiers, but I could solder new parts in it if I knew what was broken. Could someone help me troubleshoot the amp?
sgrossklass 25th December 2012 08:14 PM
ERR#900F: Pics no workee.
Still, I don't think it is advisable that you undertake a repair yourself, unless you happen to find a trivial fault like a bad solder joint at input or output jacks. Amplifiers like this typically operate on like +200..300VDC (plus there's the bias voltage of 580V), so all the usual safety precautions for tube gear apply.
Once power has been off for quite a while, you should be able to perform some basic in-circuit transistor testing, just making sure that none are dead short or open somewhere. If you are lucky, corresponding parts in the left and right channel are easily identified, so you can check whether measurements match.
randomlf 25th December 2012 10:31 PM
Quote:
Originally Posted by sgrossklass (http://www.diyaudio.com/forums/headphone-systems/226077-stax-srm-212-repair-post3298863.html#post3298863)
Hi, the pics work when you right click them and "open up a in a new tab", at least in the two computers I tried to open them :)
I have an multimeter, but I'm not sure what I should measure, like I said I don't understand much about amps. Though the pcb has clear separate sections for right and left channel, so I could easily compare them measurements.
You can also PM me if you don't want to type here.
randomlf 27th December 2012 01:38 AM
So like you can see in the pictures, the unit has 8 leds inside the unit, and they all light up when the device is on. I think there's 4 leds for each channel. Could this mean that there's at least something working on the left side.. ?
chinsettawong 27th December 2012 05:03 AM
Can't see your pictures.
Wachara C.
randomlf 28th December 2012 05:42 AM
Quote:
Originally Posted by chinsettawong (http://www.diyaudio.com/forums/headphone-systems/226077-stax-srm-212-repair-post3300351.html#post3300351)
Wachara C.
Hi, here are direct links to the pictures, just press them and you should be directed to the imageshack website.
ImageShack® - Online Photo and Video Hosting
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
