there is a proposal by tweak audio to do this among other tweaks and was wondering if anyone had experimented with this. maybe installing a small film cap across the led would make the same difference, thanks
A forward biased LED is probably quieter than any of the transistors or resistors in the circuit. The impedance is low enough that a film cap bypass does nothing other than cost money and take up space. There may be psychological benefits, but any electronic ones are dubious.
Apropos of the subject, when I first made FW amps with the blue LEDs, I
ran them at a couple ma current and they were fairly bright. This resulted
in comments about the high frequencies which went away when I dimmed
them down. Similarly, red and green LEDs elicit different perception of the
sound in a number of customers.
A guy at Woodstock, back in '67, told me, the world was soon to have zillions of tiny-plastic-light-bulbs EVERYWHERE !
"I have several hundred 'proper bulbs' stashed, just in case...man"
In case of what ? I asked...
...no reply.
Wish I had his cell #, he might have a good 'tube-pile' as well...
Si.
PS...Round here, our mate Andrew said...
" There's no LED on it ! How can you tell if it's ON ?"
I said...
"Sound comes out."
( we stuck a label on the foot-switch of his fuzz-box later...
...which said - This is NOT a foot-switch )
He was slightly 'annoyed', even though there was no red LED fitted.
...no reply.
Si.
I said...
"Sound comes out."
- Would removing the LEDs in my F4 or any FW amplifier yield better sound?
