hi all,
is it the output analogue stage of the cdp in particulare the I/V conversion performed with a IC ? If yes has it one or two dac chip for channel in push-pull so i have to try to swap the IC with a sowter very nice transformer?
Wich value of resistor do you suggest: 10 ohm for 2 volt output?
Wich is the output impedance Z out?
thanks for reading
cheers
paolo pontello venzia italy
thanks for reading
cheers
