diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   Dip in frequency response, fix ideas? (http://www.diyaudio.com/forums/full-range/224655-dip-frequency-response-fix-ideas.html)
nonsuchpro 30th November 2012 05:23 AM
Hey guys.
I bought a bunch of HiWave BMRs for a line array and am debating on how to correct the dip around 1.5k. I want to use this full range but I can hear the dip. I was thinking of a few small mid drivers with a 4th or higher narrow band filter. I have already tried this and it actually works. But before I do this I should ask you guys what else can be done that I may not have though of already.
Thanks in advance! :)
Melo theory 30th November 2012 05:29 AM
Have you listened to them in an array all ready, or just a single driver.
Melo theory 30th November 2012 05:33 AM
Once you put them in an array, they are going to exhibit comb filtering with a downward FR. So they will need eq anyway.
nonsuchpro 30th November 2012 05:33 AM
Quote:
Originally Posted by Melo theory (http://www.diyaudio.com/forums/full-range/224655-dip-frequency-response-fix-ideas-post3263718.html#post3263718)
I have done 8 drivers. I plan on using 12. I used a morel cam mid crossed 4th order from 1k to 2k and was able to adjust it's volume independently, it helped a lot.
nonsuchpro 30th November 2012 05:36 AM
Ideally I was thinking a button type driver that does 1.5k and put those beside or every other. I am using tweeters as well and augmenting bass with 8" woofers.
Melo theory 30th November 2012 05:36 AM
Have you measured the FR?
Melo theory 30th November 2012 05:37 AM
Are these the 2" BMR"s?
Nevermind, I just clicked on the link.
nonsuchpro 30th November 2012 05:39 AM
Quote:
Originally Posted by Melo theory (http://www.diyaudio.com/forums/full-range/224655-dip-frequency-response-fix-ideas-post3263728.html#post3263728)
Not yet, just going by ear and referencing other speakers. My little mixer I used for phantom power for the measurement mic died on me so as soon as I pick up another I can measure.
nonsuchpro 30th November 2012 05:40 AM
They are amazing little speakers for $6
Melo theory 30th November 2012 05:43 AM
I can't picture this speaker.
You want to use these full range you say....but you are going to use tweeters.
And mids? What like alternate the hi waves with the mids to smooth out the dip?
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
