Here is a very detailed article on the WM61A by John Conover.
A must read for all those using this capsule or planning to use it.
John Conover: Using the Panasonic WM61A as a Measurement Microphone
Has anyone taken Ray Carlisle's WM61A2.sub file and have it reflect the "Linkwitz mod"?
I've tried this and had limited success. It's not behaving exactly as expected. I basically just added an extra pin named OUT in the .asy file and then routed the JFET source to it instead of GND. I'd post the modified .sub file but I figure anyone that can help probably doesn't need to see what I didn't do correctly.
WM61A Electret Microphone Model
