Hi, I don't think this cabinet can be sim with hornresp (same space for horn and rear vent)
So is it possible with Akabak? Is someone has an exemple script? Thank.
Yes the drivers are in the two angled horn walls, it's an EAW like design EAW: SB1002
I don't have any specs, it's just to sim it and see how it can perform.
They perform like the SB1002 specs say, rising upper bass due to the "V" loading", LF output similar to any bass reflex of similar volume using the same cone. The "V" loading affords a smaller frontal area than a usual 2 x18" BR.Yes the drivers are in the two angled horn walls, it's an EAW like design EAW: SB1002
Since the port loads in to the "V", you can't get an exact match in Hornresp, but the Hornresp br/horn model is "close enough for rock and roll".
Art
