Hi all,
I have got this amp stripped but forgot to take notes.... again......
Although i was smart enough to write down the OT connections this time, I forgot the Power transformer connections between main, 110/220 switch and the PT...
But I Need to connect this PT to the 220v (236) we have over here...
Do i use both the 0-110v connections?
Also there is already a conection between the 230mA and E connection which is also connected to ground? and I wonder why...
Thanx..... again.....
looks like there is a 110v-0-110v connectiong.
you should test 230volt across the two 110s, and just forget about the 0.
probably a senter tapping.
and allso connect a 50-60 watt light bulb in series with the transformer, so it it doesnt work it just lights up instead of killing the transformer.
