Best Drive for EL34
Hi, and glad to see someone from my country , once i have made an el34 push pull once and tried a lot of tubes for voltage amp or driver and got the best result with ecc82 with no feedback , because of its lower gain than ecc83. i hope than this is useful for your amp.
Check out Tubelab Simple SE
yes and find :I settled on the 12AT7 - ECC81. This tube works almost as well as the 5842 and is available world wide for a reasonable cost.(Tubelab Home)
12at7 works well in se amps and people cant find mullard or telefunken ecc83 easily but more chance for best product ecc81.hifi tubes are different to radio tubes .Different Tube Brands ..... different sound and different price.
There are many cheeper ecc83 out there. I have some very inexpensive Chinese ones that sound surprisingly like Telefunken or Mullard..
Is 200V enough for ecc83? I find ecc83 sounds better with HT at 280V ...
If you don't need all that gain, and can't boost the volts then e88cc (or pcc88) could be a choice. You may need to elevate the heaters on e88cc though...
Personally, I would probably use ecc99 if it was 9-pin
Hi
I have Single ended Amp (DIY) with two El34, and drive them with ECC81.
one Section for each el34 and plate choke instead of resistor.
about 200 volt on Anode with 4mA.
what kind of topology (SRPP , Cascode or Anode follower ) is best for Drive El34?
thanks
One of the things you can do is use a 12AX7 but with local feedback. Conn an (about) 1Meg resister from the output back to the grid. Choose the resister to give the gain that is required for that stage. This does two things
1) greatly reduces distortion and controls the stage such that it makes not difference at all which brand tube you use. The stage will be linear.
2) Lowers the output impedance of the tube so it can better drive the power tube.
It is a very low cost solution too. About 5 cents of added cost for the resistor. I'd use the "AX" tube because it has the most gain of tube in that series and you need open loop gain if using local NFB.
Thanks for your comments.
Nobody suggested a topology like SRPP or cascode for this drive. Why?
Are they bad or useless?
Then I have planned to test some tube like 12AX7 and 12AT7 and ... and write result as soon as possible.
SRPP has too much gain, so if you don't need feedback there is no use for it. t is favored by the Chinese manufacturers for this reason.
