diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   PSU for ucd180st? (http://www.diyaudio.com/forums/class-d/220663-psu-ucd180st.html)
markusA 29th September 2012 08:14 PM
PSU for ucd180st?
I have a couple of UCD180ST modules that I want to use.
Please help me decide on what to use for psu's.
(Building two monoblocks.)
I could either bodge togeather a couple of very simple linear supplies or I could buy a set of SMPS200QR from connexelectronic.com.
The price is roughly the same when you factor in everything.
The smps is probably even cheaper than the linear supplies counting all the little bits and pieces?
The cases will be the same in either case.
Weight isn't an issue. If anything the weight from a transformer would help the amp to stay put...
I like simple and economic. If money wasn't an issue I would go ahead and buy Hypex psu's.
So, what do think is my best option?
GuidoR 29th September 2012 08:57 PM
Have a look to this Connex SMPS300RE H i F i D U I N O from an esteemed member of this forum
Guido
markusA 30th September 2012 09:45 AM
Thanks for the suggestion.
The case is only 40mm high so size might be an issue with that specific supply.
I will however e-mail Connex and ask if they can use caps with a lower profile. :)
giannettino 1st October 2012 03:57 PM
I think the DPS 500 series can be perfect...
Link
markusA 1st October 2012 04:26 PM
Looks nice but it doesn't say anything about the physical dimensions and it's way too expensive at the moment.
giannettino 1st October 2012 04:31 PM
Ok..understand..
I have a couple of them driving 4 "old" Nuforce Ref 9 V2 pcb each..and they work very good :)
Ciao!
Tekko 1st October 2012 04:45 PM
A 400VA transformer would be adequate.
markusA 1st October 2012 04:48 PM
I like power as much as the next guy but I could easily get away with 160VA transformers.
A 400VA transformer would never fit in the case anywho.
Building two monoblocks... :)
AP2 1st October 2012 04:49 PM
sorry, maybe solve very well DPS-400. it is 100x105mm and assemble in 1U. very clean smps for audio,think is in discount. maybe can help you.
I know it is already used for UDC180/400 without problem.
Koifarm 3rd October 2012 08:18 PM
Just use linearsupply with 2x10000uf caps. This sounds better then a SMPS with the ST modules. Do not try to save a view bucks.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
