I have a 52L cabinet that is in need of a full range driver. Suggestions? I need it to go all the way to 20 Khz, no cut off or it bothers me. So no pioneers or others that need a hint of a tweeter. Box could be ported or vented or small, i could add fill...
I want it to go low
KT 66 Tube amp
Virtue 2.2 amp
bedroom 15 x 18
Help
Jon
I want it to go low
KT 66 Tube amp
Virtue 2.2 amp
bedroom 15 x 18
Help
Jon
I want it to go low
KT 66 Tube amp
Virtue 2.2 amp
bedroom 15 x 18
Help
Jon
I'll only suggest drivers I've heard for myself, although none in this size enclosure
Any of the Alpairs probably - 7.3 would certainly work in smaller volume, but as you said, you could add fill blocks. 10.2 would dig much deeper, at the possible premium of some midrange depth/detail ( I know Mark hates this, but it's what I hear) 12.P? might not quite stretch to 20K, but is a pretty darn easy listen in a smallish room
Fostex FF165WK?
TB W5-1611?
You can also check SEAS FA22RCZ H1597, 8” full range driver
H1597-08 FA22RCZ
http://www.madisound.com/loudspeaker_specifications/fa22rcz_appnote.pdf
It goes 35Hz/F3 in bedroom.
uk: http://www.audio-components.co.uk/store/productdetail.asp?ProductID=4953
ca: https://www.solen.ca/pub/index.php?...eau1=1&niveau2=1&niveau3=9&s1=2&s2=1&s3=2&s4=
us: http://www.madisoundspeakerstore.com/approx-8-fullrange/seas-prestige-fa22rcz-h1597-08-8-fullrange/
de: https://www.intertechnik.de/Shop/Lo...peaker/_71716_H14-FA22RCZ_1768,en,7018,115047
H1597-08 FA22RCZ
