diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   How hot KT88 get? Anybody take a reading? (http://www.diyaudio.com/forums/tubes-valves/219393-hot-kt88-reading.html)
jhl1963 9th September 2012 07:03 PM
Hi guys, has anybody taken an IR reading how how hot these tubes actually get at the glass, 1" above/ 3" above etc or any reading for reference for that matter? We talking 120/150/200 degrees f?
Thanks a bunch!
speakerfritz 9th September 2012 08:50 PM
in actual use it will vary...most kt-88's have a max allowable spot temp of 250 C.
Bob01605 9th September 2012 09:43 PM
Below are the temperature readings (in Fahrenheit) at various points on a VTA ST-120 tube amp that had been on for 5 1/2 hours playing music at normal volume levels. The ambient temperature was 69 degrees F. The tubes used were the Tung-Sol KT120 output tubes rather than KT88's. KT88's would (IMHO) give slightly lower readings. Plate temperatures of the KT120's were over 300 degrees F on the REAR tubes but under 300 degrees on the FRONT tubes which have better access to circulating air. I neglected to take a reading on the Weber WZ68 solid state rectifier used in the test but it was plenty hot also. Note that the left side of the amp is warmer than the right side. This is normal for an ST-70 type amp because the rectifier (tube or solid state) is on the left and passes plenty of current. This adds extra heat to the left side of the amp.
Bob Latino
http://i9.photobucket.com/albums/a78...e2withtext.jpg
jhl1963 10th September 2012 11:55 AM
Thanks Bob, this is helpful.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
