Hopefully a simple question.
This a hopefully a simple question. What damage, if any, does leaving a heater always on, on a tube such as a 12ax7, with B+ only applied when in use, do to the tube? The voltage for the heater would be DC.
I'm not thinking of using some rare Telefunken just the cheap everyday run of the mill Chinese 12ax7b. The heater supply would be a external 12volt switching supply with a old but very lightly used 6800uf computer filter capacitor, bigger than most output tubes.
This is a mod so it would be easier to keep it external. I've already done the mod and the circuit is now dead silent. The problem is wiring in the heater power supply so it turns off and on with the amp, would be be a slight pain.
Thanks James,
Thanks James,
In the last days of tube TV's the manufacturers sold "Instant On" sets that kept the filaments warm while the set was off. Not sure if the filament voltage was full or maybe 75% but it actually had the affect of reducing tube failure due to hot/cold cycles of the filament.
Very often in the standby mode a diode was inserted, thus reducing the power consumption of the heater chain to somewhat more than 50 %.
Greez!
Others were specially designed, but as the aim was switching they didn't worry too much about linearity.
Please have a look at the E 90 CC and the E 92 CC curves. In my eyes these computer valves (designed for Windows 58...) don't seem to be too un-linear, do they?
Btw: They are cheap, too, especially if you consider the RFT counterparts ECC 960 and ECC 962, respectively.
Best regards!
Well, if you had a CCS at the anode, and ran them at about 5mA and 300V B+, the result might actually be quite acceptable. Then again, the same operating conditions with a truly linear triode like the ECC99 from JJ Electronics results in very low distortion.
One thing often mentioned in the datasheets of these computer triodes is that they're prone to microphony. That's a thing to take into consideration when designing audio equipment.
Find the RCA 6201 (12AT7 type) data sheet. It has very interesting design notes, for use under cutoff, on/off controls, and high vibration environments. Sounds like the perfect tube.
