Please find attached schematic.
Transformer 18-0-18 = Rectifier Bridge = 4700uf Cap = 0.1uf = Regulator = 0.1uf
25(+/-) is for LM1875
18(+/-) is for NE5532 preamp
1) Correct way to separate 0V to Ground by 1R resistor, before regulator or after regulator ?
2) I want +5V supply, So where should I use 7805 Regulator ?
LM1875 ratings +/- 25V for 4ohms, +/- 30V for 8ohms. Don't use any devices near Vcc max.Keep a 10-30% margin e.g. I use 2 independent SMPS for LM1875 chipamp bought @ Rs 350/- each having rating 21V/4.0A. Connected in series resulting +/- 21V/4.0A they shake foundations! Using transformer/rectifier/linear regulators only increases heat losses.For +5V(assuming you are using generic USB mp3 player) I suggest you use mobile charger adapter. Simply cut the end wires & solder any DC pin of your choice.
Thank you all,
@Andrew : I tried to copy from the link. Pluto electronics
Instead of using 2.2R I am using 1R. Your "Audio Component Grounding and Interconnection" link is good I am reading....
@availlyrics : You got the point,
1) 25(+/-)VDC I want for LM1875
2) 18(5/-)VDC for NE5532 preamp]
3) +5VDC for USB mp3 player.
Mobile charger adapter is good choice, what is the disadvantage to pick +5VDC from main power supply.
where are you proposing to place the resistor?Thank you all,
I have already said
neither
- Chip Amps
- Help on power supply for Chip Amp & Op Amp
