What is this gadget? It's made by Sennheiser
The attached photos, have a look and can somebody tell me what this is and/or what it's for? The end of the main body accepts a 2.5mm stereo plug, one that must have a small diameter plastic molding over the soldered connections because it's a small opening there. The main body has a rotary volume control and an off/on slide switch. The end opposite the 2.5mm female jack has two wires, each terminated with a 3.5mm male stereo plug. One of these plugs has a mic icon embossed on it and the other has a headphone icon. I found this thing at a local Goodwill store and paid 99 cents for the thing so I could bring it home and figure out what the heck it's for. Thanks in advance.
It could be an adapter from a 3 or 4 connection earpiece/microphone headset (or earbud) used for cel phones to regular computer speaker / microphone set
99 cents...autopsy
Autopsy has been performed. The 2.5mm jack has only 3 connections, ground, right and left. Or put more technically sleeve, 1 ring and tip. You may be right about it being used to connect a cell phone to computer. But would that be of any use? And why the on/off switch or the volume control? Why the stereo plugs, why not mono? Thanks for your reply.
Looks like an inline volume control with an on/off switch for the mic. Probably also converts seperate sound and mic jacks to a single 4-pin output for a headset.
The potentiometer in these things are usually around 500R.
When I had it apart I saw only three soldered connections on the jack so a four pin headset would not be of any use.
It has been explained already! The thing is an adapter that connects a certain Sennheiser headset to a sound card. It uses only one ground for mic and the mono headphone. The pot is the volume ctrl for the headphone. The switch is used to mute the mic.
I was using these things for an intercom my company makes. It bugged me that I could not use the little chip amp in that intercom (TDA 7050) in BTM because the headphone had one side grounded.
So, no mic in the gadget. Hardly any use without the headset.
Well, all righty then! Thanks for your detailed description. What kept throwing me off was the use of stereo plugs on both mic and headphone. Now I see only one non-ground connection was used, either tip or ring. Thanks again.
