Hi
I have the finished DAC use the WM8741 & TE7022 & WM8805 chips.
WM8741 is a very high performance stereo DAC designed for audio applications,it is the best DAC chip so far,Audiophile's goal of DAC DIY project.It is in professional design to obtain very good sounding
If anyone is interested please chack hear:New DAC Decoder TE7022 USB WM8741 WM8805 Coaxial Optical 24Bit
On this diyaudio forums have a discuss about this DAC: WEILIANG DAC5 - WM8741 & Tenor TE7022
Thanks!
Thanks!
Is it available assembled without the case?
Hello, it is OK for asssemble without case as you want! You can check the link here Thanks!
If anyone is interested the parts kit (not soldered),please check the link here :WM8741 WM8805 Coaxial Optical DAC Decoder Digital To Analog Kit
Thanks!
http://diyhifishop.com/wm8741-wm8805-coaxial-optical-dac-decoder-digital-to-analog-kit-p-55.html
Thanks!
And please note this board is the newest verision by weiliang: V1.9
The designer improve many details on this version.
Hi All
I just got one of theas wolfson WM8741 & TE7022 & WM8805 DACs
It’s only been running for an hour and seems to be a promising sounding dac with the standard op amps
However
The one design fault for me is with the very hot regulator heat sinks heating up the capacitors as thay are getting to hot and this will shorten the cap life alarmingly
finally, after 3 months I started soldering it, and looks like I am one 0.1uf capacitor short..
I got only 11, how many have you got?
Ignore my last comment, figured it out
- Vendor's Bazaar
- FS:Finished USB DAC - WM8741 & Tenor TE7022
