Hi all,
Have some new great quality 12 Inch Jaycar speakers for sale, specs including most thiele small parameters are further down and detailed pics are attachments.
I personally bought these from Jaycar years back and just don't have the chance to use them. So out they go! Kids came along, and no more time. Familliar story for most.
The Woofers were bought for a 3 way Hi-Fi speaker build, and go down to 25Hz easily, and the Guitar speakers were for a marshall quad box clone for a tube guitar amp project. Both are no longer stocked by Jaycar, so now vintage I guess Jaycar have a reputation for excellent quality speakers.
Available are:
3x 12" HI-Fi Polycone rubber surround Woofers
4x 12" Guitar Speakers
2x 12" Steel Grille kits
All are in original boxes as new. Never been used.
Asking price for speakers is $50 each plus postage and Grilles are $10 each.
Located in Tasmania / Australia. The speakers weigh between 3.1 and 4kg each packed and are in 34x34x16cm boxes. Overseas postage is probably out of the question, sorry.
PM or post if you are interested or want to make an offer or deal. Buy enough speakers and I'll throw in the grilles for free!!
6J6.
CG2380 - 12 Inch Guitar / Sound Reinforcement Speaker
This 12" / 300mm driver has a black cardboard cone, magnet weight of 38.7oz (1097g) and an aluminium dust cap. Best performance is achieved in sealed enclosures. Two examples are given below.
Specifications:
Impedance: 8 Ohms
Power handling: 100Watts RMS
Frequency Range: 68 Hz-3000Hz
Sensitivity: 94dB 1Watt 1m
Voice Coil Resistance: 7.2 Ohm
Resonant Frequency (fs) : 68Hz
Mechanical Q factor (Qms) : 3.241
Electrical Q Factor (Qes) : 1.237
Total Q factor (Qts) : 0.895
Equivalent volume (Vas) : 53Lt
Cone Area (square metres) : 0.506
Typical Applications:
Sealed Box
Box Volume (litres) : 80Lt
Tuning Freq (Hz) : 97Hz
-3dB Freq (Hz) : 65Hz
Qtc:1.15
Inside cabinet dimentions: W: 400mm; D: 330mm; H:600mm
Sealed Box
Box Volume (Litres): 40Lt
Tuning Freq (Hz) :103
-3dB Freq (Hz) : 74
Qtc:1.36
Inside cabinet dimentions: W: 380mm; D: 220mm; H: 480mm
CW2130 - 12 Inch Polycone Woofer
This 12" / 300mm driver has a 30oz (850g) magnet and a black polypropylene cone with a rubber surround. Suitable for sealed or vented boxes, the latter giving best bass extension.
Specifications:
Impedance: 8ohms
Voice Coil Resistance (Re): 7.4ohms
Power handling: 80watts RMS
Frequency range: 25Hz - 4000Hz
Sensitivity: 92dB 1watt 1metre
Resonant frequency (fs): 25Hz
Mechanical Q factor (Qms): 5.262
Electrical Q factor (Qes): 0.428
Total Q factor (Qts): 0.396
Equivalent Volume (Vas): 194Lt
Cone Area (square metres): 0.0506
Typical Box Applications:
Vented Box- Box volume (litres): 100Lt- Tuning Freq (Hz): 25Hz- - 3db Frequency (Hz): 33Hz- Two Vent Options:Vent dia: 66mm Vent length: 116mmVent dia: 85mm Vent length: 229mm- Inside Cabinet Dimensions:W: 370mm; D: 350mm; H: 780mm
Sealed Box- Box Volume (litres): 60Lt- Tuning Freq (Hz): 51.4- - 3db Freq (Hz): 45.4- Qtc: 0.82- Inside Cabinet Dimensions:W: 350mm; D: 300mm; H: 575mm.- Speaker dimensions: OD(A) 310- Mounting holes B 293mm , Cutout C 276mm.
Available are:
6J6.
Specifications:
Impedance: 8 Ohms
Sealed Box
Qtc:1.15
Sealed Box
-3dB Freq (Hz) : 74
Qtc:1.36
Specifications:
Impedance: 8ohms
