adding opamp filter stage
Hi, I have this schematic:
But I would like to add one more parametric filter for the mids, so changed it to:
Did I get it right? Just simply cloning by analogy.
The part of the schematic above the PQ filter (U2.x)
- these opamps are, stage buffers, followers?
Is it ok I just clone it that way?
Best Regards
I have no experience with this, but your circuit will have 2 band filters working on the same bandwidth. I don't know if this is common or not, but the operational problem I see is to control the real interaction, e.g. to know/predict the total boost/cut when both filters working on very close frequencies. At least, the more filter you added, I expect a sharper Q (i.e. to have a higher fixed maximum Q by increasing resistors in series with the pot for adjusting Q).
I only comment by logic. Not really know the common practice.
the frequency range of the two parametric sections I will adjust later on.
f.ex. they might overlap for one octave, now the range is 4 or more.
Saving one opamp is cause there are 3 more outside this schematic and then I would have 12 in 6 dil's.
One for the input, one for simple low/high filter, and one for the output. Input is preamp, output is maybe impendance issue, not sure there are too many already..
Thx for the Rane corporation LInk !!
still confused about the circuit's design, cannot recognize the topologies and 'what does what' completely.
If someone can point me what the parametric section is (topology to read about).
Also, the upper part, where the parametric sections are connected - some followers or whatever.. is that part of the filter or smth else
