diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Diamond D3 1100.1 driver board (http://www.diyaudio.com/forums/car-audio/212081-diamond-d3-1100-1-driver-board.html)
brandes.cm 4th May 2012 12:25 PM
Anyone have info on these, gate resistors tie directly to the soic near the two smaller ic's.
http://img.tapatalk.com/aefd82c3-ca9b-c4eb.jpg
http://img.tapatalk.com/aefd82c3-caaf-b2a3.jpg
Perry Babin 4th May 2012 05:04 PM
I've never seen this amp but some of the Diamond amps use a IR2184S to drive the outputs.
brandes.cm 4th May 2012 05:25 PM
I will give that a try.
The smaller packaged IC's are marked with H08, any idea.
Perry Babin 4th May 2012 06:50 PM
Possibly this:
http://datasheet.octopart.com/TC7WH0...heet-63725.pdf
brandes.cm 2nd June 2012 11:16 PM
http://img.tapatalk.com/a6fae330-9e20-7411.jpg
http://img.tapatalk.com/a6fae330-9e53-8a78.jpg
Anyone seen a layout like this? I get no gate signal. I replaced what I think is the ir2184s, no luck.
MatthewS 3rd June 2012 01:43 AM
I absolutely loathe opening up Diamond D series amplifiers.. I realize that's of no significance here, but I had an opportunity to vent. Good luck Sir..
- Matt
brandes.cm 3rd June 2012 01:59 AM
The D3 1000 doesn't have this encapsulated module and is easier to work one. These are a pain.
timwebb 3rd June 2012 11:39 PM
ive never seen that design in any amp.
MarioLaul 4th July 2013 09:06 AM
Hi, what is driver output mark?
whether it is possible to find it somewhere in the scheme?
evianamp2011 5th July 2013 03:48 AM
I worked on a Diamond D600.1 recently and have some pics. Let me know if that would help, its not as complicated (not as many traces and components) as yours but it looks similar.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
