I am just getting into digital audio from a quality sound system point of view and I am looking to be able to understand some of the technology available to the general public.
I have read some information (not specs) but just general information and of course that peaked my interest in learning more.
Right now, my set up is this....I have an AudioSource AMP-100 Stereo Power Amplifier, ADC SS100-SL 10 band Graphic EQ, and a decent set of Harvard 3 way speakers that will be fed from a windows pc with vista.
I was reading that you get a cleaner (?) source from the PC through a USB cable into a DAC... and that this will by-pass the onboard sound card? Is this correct?
If it is in fact how this operates, would i need software that directs the sound through the USB cable? Would i play my audio files through my media player or would i also need a specific player? I currently have winamp pro that i play all my FLAC's through, but could/would change to another software package if need be.
Any information would greatly be appreciated...
Thanks,
Joonze
PS. I also have a few questions in a post in the PC Based Forum if you can help with those questions too.
Thanks,
Joonze
Thanks for your reply.... i checked out the link provided and its very technical. Informative, but with all the acronyms its hard to follow since i don't know they mean. Is there a place, forum for dummies, or some very basic information that you might point me towards that will get me up to speed?
I have read several post over that past day or two, any this seems like a very friendly and helpful forum...I am looking to learn from a great group of audio enthusiast...
I just started doing something similar.
I have a laptop with Vista and a USB dac..........
MUSE USB to Optical S/PDIF Converter DAC DTS External Sound Card | eBay
but i only use it as a converter to get co axial SPDIF from the laptop. Can't comment on the inbuilt DAC as i haven't tried it yet.
It's plug and play with Vista, and should work with any media player that handles FLAC files. I use Clementine.
Haven't noticed any drop in quality from using a CD player as transport. Might even be better.
Wether USB->DAC is better/cleaner depends on the DAC. USB input on a DAC replaces your soundcard (a soundcard is a DAC and an ADC), your PC will just see the DAC as an USB-soundcard, which you can select as output device in the media player or set as default for the whole OS.I was reading that you get a cleaner (?) source from the PC through a USB cable into a DAC... and that this will by-pass the onboard sound card? Is this correct?
-- Sent from my Palm Veer using Forums
What runs the usb port in an external usb dac.
This was my question, the same one as Joonze's.
Thanks for the clear answer. However, if I am reading FLAC files, I will be coming off of foobar, not Win media player. if I reset my audio globally, I will have no simple L and R for skype and youtube etc.
This seems to limit me to lossless WMA, which is really OK, but I have become used to Flac.
Also I gather that sound-card issues are irrelevant---I am using intel chip-based sound.
Of course, it depends on your sound card and your external DAC. However, both USB DACs I've used (the Behringer UCA222 and Twisted Pear USB receiver/DAC) were less noisy than the soundcards in the computers they were used with.I was reading that you get a cleaner (?) source from the PC through a USB cable into a DAC... and that this will by-pass the onboard sound card? Is this correct?
No.If it is in fact how this operates, would i need software that directs the sound through the USB cable?
Your current media player will be fine.Would i play my audio files through my media player or would i also need a specific player?
Of the two I've used, the Behringer and the Twisted Pear, I think the Twisted Pear sounds better, though it's also more expensive, and is just a PCB to which you have to solder some components yourself. You'll also need to supply your own RCA phono jacks, hook-up wire, and a little box to put it in. All of these will be available at Radio Shack.
Happy listening!
- Digital Line Level
- Tell me about USB DAC's
