diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubelab (http://www.diyaudio.com/forums/tubelab/)
-   -   Simple SE Build - Noob question (http://www.diyaudio.com/forums/tubelab/208911-simple-se-build-noob-question.html)
AustinIrons 16th March 2012 07:29 AM
First amp DIY project and had a few questions that I hope you guys could help me with. I'm a mechanical engineer by training so trying to read a simple wiring schematic is a real head scratcher for me. The board is soldered so while waiting for the Edcor transformers to get here, I'm figuring out the chassis portion of the project.
I would like to add 2 sets of inputs to the chassis; the primary inputs will be dedicated to the phono preamp while the secondary inputs will give me the flexibility to add another line source in the future (DAC, etc). My question is, what type of switch will I need? Do I need a 4PDT, where both sets of L+R inputs are all wired to the switch and then out to the volume knob? Or should I use a DPDT, where only the hot sides of the inputs are connected to the switch and the neutrals go directly to the volume pot? Or am I totally off base on everything? Any help would be greatly appreciated, along with any wiring tips you may have. Thanks!
rknize 16th March 2012 03:43 PM
If you were using balanced inputs, then you may want to use a 4P switch (depending on the amp). If you are just using RCA jacks like most builders, then a DP switch works just fine. All of the shields on the SSE will terminate to a common point anyway, so a DPDT will do the job.
AustinIrons 17th March 2012 06:13 AM
Thanks Russ!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
