nedd az1 tube base in the UK
You're a very brave man, wanting to use a side contact valve - only Philips and Mullard made them, and they were rarely used after WWII - Octal based valves had more reliable bases and were less noisy. I'd be inclined to change the base and replace the AZ1 with a 4 volt Octal rectifier, possibly an AZ31, but if you want to use an AZ1 I think you will have to try a vintage radio site.
You could try Past Times Radio (http://www.pasttimesradio.co.uk/) located in the north of England, they have a 'junk' section with parts removed from old radio sets - drop them an e-mail and ask if they have a base. Otherwise post a message on the Vintage Radio and Repair Discussion Forum (http://www.vintage-radio.com/cgi-bin/yabb/YaBB.pl#general) in their 'Parts Wanted' thread. Otherwise you might have to wait for the next National Vintage and Communications Fair at the NEC.
Well, the NVCF is probably a bit expensive if you are only looking for a valve base - £15 (approx $25) admission and £6 (approx $10) for parking, plus the cost of getting there and the prices of stuff aren't cheap either. I've haven't been for a long time.
I believe that there is a vintage radio rally at Cowbit in Lincolnshire in November, and the prices there would be cheaper. Alternatively Raja could try posting a wanted ad on the Vintage Radio Emporium (http://www.vintageradio.info/).
diyAudio Senior Member
Joined 2002
Good idea, James.
And I think he's got some as well.
Raja,
The one you need is marked "P":
Cheeers,;)
