Krell DVD Standard Region Code
Just another Moderator
Joined 2003
Hi ducz and welcome to diyAudio. I don't know how to reset your region code, but google might help. I know my Marantz DV18 uses some tricks with the setup menus using particular key sequences on the remote control, but I don't know that is a factory thing as there was a note in the box that it had been opened due to region code modification, probably just a firmware update I suspect.
Tony.
