8 ohm test speaker load
Hello all,
I wand to test some 100 wat amps which are 8 ohm speaker outputs but don't have a dummy load. I measured my electric kettle which is 7.8 ohms and rated 1500 watts. I suppose it's a straight resistance load, with hardly any inductance to speak of. Is that resistance value close enough and acceptable to use as a load for testing power output.
thanks
Denis
