I would like to tackle the challenge of building my own power amp for my speakers. My current one, a Kenwood, sounds decent, but doens't allow my high quality speakers to sound as good as they can (B&W series 500). So, I began looking for a way to build a new amp and came thought of using a bridged 3886. I know a single 3886 sounds excellent, so I would think that in brided mode, running about 200W, they would sound even better. I would like to get an opinion on how well this would work. I plan on using the schematic on page 1 of National semi's datasheet, and using the Simpelest ever bridging adapter at www.sound.westhost.com. I have created a graphic of the PCB, and it is attached. If you are wondering about the many extra pads, they are for jumpers. I would make 2 of these boards, as one board does each channel. Will this blow away the sound quality of the Kenwood 2 channel tumer, or will it not sound as good? Thanks for your opinion
-Mike
-Mike
Yeah, when I searched, I found a lot about the 3886, but not much about it in bridge mode. I heard that they cannot drive 4-ohm in bridge. Is that true? Also, I didn't find much about the sound quality compared to a cheap commercial amp? Is there a noticable increase of quality, ie. volume before it distorts?
Thanks for your help, Mike
Also, does anybody know where I could find that paper that lets you print PCBs from a laser printer for the chapest? I choked when I saw DigiKeys price for only 5 sheets.
4 ohm Bridge LM3886
to supply enough current into 4 ohms you must create a bridged/parallel amp. I think it's explained well in the newest app note or in the first. To many application notes floating around in my head. Look and or ask some of the gurus on this site and you will get some answers.
Mark
Mark
Two LM3886s in bridge mode into a load are the same as each LM3886 driving half of the load. So bridging into a 4-ohm load would be the same as each amp driving a 2-ohm load, which is not recommended.soundNERD said:Yeah, when I searched, I found a lot about the 3886, but not much about it in bridge mode. I heard that they cannot drive 4-ohm in bridge. Is that true? Also, I didn't find much about the sound quality compared to a cheap commercial amp? Is there a noticable increase of quality, ie. volume before it distorts?
I can't say for sure on the sound quality compared to a cheap commercial amp (how cheap?) , but I would guess much better.
You should be aware that these amps apparently sound terrible if they are overdriven, anywhere near clipping. If you want lots of power, there are probably better choices; I find the whole parallel / bridging arrangement too complex and can see it causing you a lot of grief.
Hi Mike,
as others already pointed out it doesn´t always make sense to bridge an amplifier.
You should read the AN-1192 application note from National Semiconductors to understand what it´s all about.
Have a look here as well for a calculation tool : Spreadsheet from National
I can´t seem to find infos about the B&W 500 series but usually B&W-speakers have efficiencies of 90dB+.
You probably are quite satisfied with single chip configuration.
Choose something like +-35V-rails for 8Ohm speakers and about +-28 for 4Ohm speakers.
If you´d choose to go single chip and wire everything p2p go for the LM3875 as you´d only need 5 pins to connect.
Cheers
Jens
Cheers
Jens
If I birdge them, won't I, for sure, get louder and crisper sound with much less distortion into 8-ohms? That was my understaning. Are there any chips that can deliver much more power, and still manage to sound very good? I would like to stick with the 3886, since I have already spent hours desiging the PCB layout on the computer, and I have heard that the sound is excellent. Somebody was mentioning about the datasheet. The datasheet I have has no circuits for bridge/parallel. Could anybody e-mail me the one that does? Thanks.
Also, about my speakers, the data is at www.bwspeakers.com, then search for DM580. There is a pdf file with specs.
Thanks, guys, for all of your help. I am rather new to electronics, so if I ask some dumb questions, please don't laugh or anything.
I should think that the 3886 should have no problem with a 4 ohm load or it would be a very poor design indeed. In practice, speaker impedance can vary quite a bit over audible frequencies so most amps have been made with enough damping factor to deal with it.
Before the mono/stereo/bridge switch, bridging used to be done all the time in PA or SR installations using 2 amps, 2 interconnects and some solder. From your source, you would run a Y-split into 2 cables. One of the cables would be rewired so that polarity was reversed. The speaker pos would be connected to the amp pos with the "true" polarity and the speaker neg connected to the other amp pos terminal. Both amp's neg is NOT connected.
Unless the LMx8xx cannot handle the halved impedance, there should be no reason why they cannot be hard-wired in a bridged configuration.
My question then, is this: Can you "fool" the bridged amp output with an 8 ohm power resistor in series with the speaker.
ensen.
ensen.
Mike,
here´s the link for the AN-1192.
Go to the bottom of the page, there you can download the application note. It should clear things up.
With a bridged amplifier you´ll get more output power but having for example a 4Ohm speaker with it the amp would be current limited. Play a little with the calculation tool.
If you wanna heat up your room with the power resistor or keep your cup of tea warm it would be a solution...
Cheers
Jens
If I don´t get wrong what you´re trying to do you can rather use a single chip (so not bridged) and "omit" the power resistor.My question then, is this: Can you "fool" the bridged amp output with an 8 ohm power resistor in series with the speaker.
Cheers
Jens
http://www.diyaudio.com/forums/showthread.php?goto=newpost&threadid=19896
Just saw this interesting thread about NatSemi tools for LMx8xx chips.
ensen.
- who likes hot tea while listening to music... ;-P
ensen.
Me!- who likes hot tea while listening to music... ;-P
Most of the time I prefer a cold can but sometimes a hot tea is just right.
You might laugh thinking about it but I originally planned my class-a headphone amp for the PC so that the heatsink sits on top and I can put my cup on it...
Jens - thinks that this forum is just right for fanatics
Go to a PA equipment store and listen to the active studio monitors with CDs you are familiar with. Brands like Mackie and Genelec use chip amps in their power packs.
I have a pair of Yorkville YSM1p's and they have 3886's inside. They are a steal at about $800 Cdn for the pair.
ensen.
Warning, once you listen to studio monitors, you'll wonder why they are so inexpensive.
ensen.
I was wondering if it was possible to make the amps switch between normal, bridged and parallel. I know you can use a DPDT switch for bridged/normal, but I have never used parallel before and was wondering if I could make a stereo amp using 4 3886s and be able to switch between the 3 modes. I am using the schematic on the first page of nationals datasheet
Thanks for the help, Mike
soundNERD said:Also, does anybody know where I could find that paper that lets you print PCBs from a laser printer for the chapest? I choked when I saw DigiKeys price for only 5 sheets.
I'd HIGHLY recommend not going for cheap stuff here. My friend and I tried SEVERAL methods including transparencies, "treated" transparencies, HP Photo paper, etc etc...ALL came out with poor results that required about 30+ mins on PCB pen work on either side of the board. We then discovered Press N' Peel Blue...works perfectly. Honestly, I can't tell you how much time, effort, and money we put in before the press n' peel. The stuff may be a bit expensive but it's worth it. Try:
http://www.techniks.com/
http://www.allelectronics.com/cgi-bin/category.cgi?item=TEK-5&type=store&category=445
Hope it helps,
Doovieman
One more thing. With my (little) experience of bridged amps, I know that i have had to invert inputs on one of the two amps, having the first + and the second -? But in the briding adapter @ www.sound.westhost.com, the circuit doesn't show inverting one amp. Do I or don't I?
-Mike
-Mike
p2p, point to point. basically no PCB, just soldering the resistors and wires directly to the pins by using surgical ninja skills.
which circut. in the "simple" version, the botttom opamp is inverted.
from this circut, the input to both amps are both normal. the input to the first is +V, the second is -V.
For the active adaptor (Proj 14) one of the op-amps gives the inversion by accepting the channels "ground" and sending it on to the one of the power amps. As you can see, the + out goes to power amp that driver the speaker + terminal and the - out goes to the power amp that drives the speaker - terminal. As always don't connect the - outputs of the power amps.
The simple adaptor (Proj 20) assumes you are breaking open a 2-channel amp (stereo, dual mono, etc.) and hot-wiring it so that it accepts a lone signal into the L channel. The L amp + terminal goes into the speaker + terminal and the R amp + terminal goes into the speaker - terminal.
If you think of the various modules as "black boxes" then the connects are the same as my original post about bridging. The fact is that bridging creates a "balanced" signal that is then fed to 2 power amps whose + outputs are connected to a speaker.
ensen.
ensen.
- Chip Amps
- LM3886 amplifier
