Maybe one of these will work.
Digi-Key - ED1720-ND (Manufacturer - EDZ950/5)
http://dkc3.digikey.com/PDF/US2011/P0349.pdf
There are 2 pin spacings. One is 5mm, the other is 5.08mm (0.2"). Order the one with the correct spacing.
No numbers. My thumb is about 1" wide. The plug is probably smaller than adequate even for this thor amp. Theres a chance maybe the Boltar amp uses a bigger plug? it just seems small to me, smaller than what PPI or Orion used to use.
If it were me and I had to guess, I'd buy the plug with 0.2" spacing as this is an american amp. 5mm may not work
Yea the pictured Thor amp has power hard-wired.
- General Interest
- Car Audio
- HiFonics Boltar VIII harness
