diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   LM3886 with Dantimax pre-amp (http://www.diyaudio.com/forums/chip-amps/203912-lm3886-dantimax-pre-amp.html)
Corpius 6th January 2012 04:28 PM
I'm thinking of using a Dantimax pre-amp with my lm3886 amp. Should I go for the active or passive version?
Dantimax - Remote controlled "passive preamp" kit
Dantimax - Remote controlled preamp kit
What are the benifits and downsides of a active and pasive pre-amp?
Bone 6th January 2012 06:09 PM
It all depends if you need any extra gain. If your source will drive the 3886 to full output use the passive version. If it needs further amplification you will need the RemPre.
AndrewT 7th January 2012 10:34 AM
It all depends on the relative input and output impedances, as well as the system gain/s you require.
Corpius 8th January 2012 09:41 AM
I will try it with just a volume pot first. If this works fine there is no need for a active pre-amp.
Had anyone had some experiences with the Dantimax kits?
AndrewT 8th January 2012 09:56 AM
Quote:
Originally Posted by Corpius (http://www.diyaudio.com/forums/chip-amps/203912-lm3886-dantimax-pre-amp-post2851704.html#post2851704)
this only addresses the system gain.
You must look at the input and output impedances.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
