diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   PC Based (http://www.diyaudio.com/forums/pc-based/)
-   -   Music Main board for diyer (http://www.diyaudio.com/forums/pc-based/201908-music-main-board-diyer.html)
castleeric 6th December 2011 01:03 AM
Music Main board for diyer.
I plan build embedded board for single purpose playing back music. May people can have suggest for my project.
The spec as follows
CPU :VIA NanoTM ULV 1.0 GHz 533 MHz 5.0 W @ FlexVID
Chipset: VIA VX800
Audio control IC: VIA Vinyl Envy24MT PCI Audio Controller on broad
Ram: DDR2 SDRAM 4G on broad
Audio clock X 2 :
1ppm TCXO49.152 MHz (for 48,96,192 KHz)
1ppm TCXO22.5792 MHz ( for 44.1,88.2,176.4 KHz)
PCI-E: north bridge PCI-E only for Audio control IC on broad
USB X 2
SATA X 2
Ethernet X 1
PS/2 X 1
Power:
Main broad power: DC 12V
FAN power: none, Fanless , CPU & chipset mount on back side of MB, the bottom of case can use as heat sink.
SATA HD power: None on MB, Supply from independence power supply
Audio control IC power: None on MB, Supply from independence power supply
Audio clock 1ppm TCXO power: None on MB, Supply from independence power supply
Output
SPDIF output X 1 (out put transformer Option)
I2S output X 1
VGA X1
Selector
Audio control IC DAC function En & disable
Audio control IC analog power En & disable
Display function En & disable
Disable
Disable Envy24MT ACD and analog input
Disable Envy24MT AC 97; AC link function.
Disable Envy24MT I2C out put.
Disable Envy24MT UART
Disable VX800 audio function
Connector :
power connector on broad ,
SATA connector on broad
VGA connector on broad
On/off connector on broad
LED connector on broad
Driver:
windows driver & Linux driver
GloBug 9th December 2011 12:04 PM
Sounds like a really cool project, subscribed.
acvtre 11th December 2011 12:27 PM
Quote:
Originally Posted by GloBug (http://www.diyaudio.com/forums/pc-based/201908-music-main-board-diyer-post2812958.html#post2812958)
subscribed.
Me too. I would add:
- a wifi module, so that it's easier to control it via phone or link to a NAS;
- a mini storage, something like a CF, where to install a light OS like voyage mpd;
- IMHO there's too much ram, I think that 2 gb would be enough.
How do you think to realize/produce this project?
How much would cost a mainboard like this?
And what is the form factor?
Plus: would be really cool if you add also a suggested powersupply or a schematic to build it.
GREAT IDEA DUDE! :D
castleeric 11th December 2011 01:46 PM
Quote:
Originally Posted by acvtre (http://www.diyaudio.com/forums/pc-based/201908-music-main-board-diyer-post2815442.html#post2815442)
GREAT IDEA DUDE! :D
hi Acvtre thanks for your input.
I think the wifi module make noise easy to audio signal, I try make a pure bit stream MB. So I think connent AP or HUB to make wifi function, Just for in case.
mini storage, Yes,I plan 64MB in BIOS for user.
Cause try to reduce PCI bridge complex, I didnt plan to use CF function. There is small SSD SATA cheap and fast for different OS.
One 24/192 program is almost 4G , After this project I hope can star another driver & program project, at that time upload play list to ram use DMA channel mapping to audio IC. so I think need that.
I got VIA pepole support to make it come turth. I didnt get all the cost. but I hope it will be lower 650 USD, I am not sure for now.
The form factor not decided and will not follow the PC base.
Power supply will make sound different. I do not know what is right way. Hope pepole can try then.
Hope I can make it.
acvtre 11th December 2011 03:56 PM
What have you got/done so far?
I mean have you already got a prototype or something similar or this one, that you have exposed is just an idea?
castleeric 11th December 2011 11:58 PM
Quote:
Originally Posted by acvtre (http://www.diyaudio.com/forums/pc-based/201908-music-main-board-diyer-post2815689.html#post2815689)
Now is main broad design stage. Next trying make egineering sample and prototype.
acvtre 14th January 2012 11:52 AM
How's going the work?
terranigma 17th January 2012 06:19 PM
Which dac chip is going to be used? Or will MB contain I2S headers for external dac chip?
castleeric 4th February 2012 01:40 PM
I change the architecutre to intel atom E640, the first engineering sample will be done on the end of March. I will paste the picture then.
Quote:
Originally Posted by acvtre (http://www.diyaudio.com/forums/pc-based/201908-music-main-board-diyer-post2861462.html#post2861462)
castleeric 4th February 2012 01:50 PM
VIA Envy24 HT has DAC funtion. I chouse it because it support dual XO(48,44.1 base) input. But I will not use DAC function. There is I2S RJ45 connector on broad.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
