Reached the checkout stage, and must confess a bit nervous. Read and re-read the checkout/bias sections of the manual, a couple of questions ...
Near the end I do the "slowly adjust pots R12 R23 to raise output tube current to desired."
What is the desired output tube current for 45s?
What is the acceptable range for B+ in a 45 TSE?
One more question. I have breadboarded the amp at present. I have Electraprint OPTs - do I need to ground the outputs from these?
Grounding the speaker negative assures nothing is floating, and at my house, I sometimes run vintage Polk SDA speakers (with an umbilical between them) that requires the speaker -ve to be grounded.
I'm no expert, but IIRC it's also important to ground the speaker -ve when running gnfb (not the case here, of course)......
- More Vendors...
- Tubelab
- 45 TSE desired tube current? Acceptable B+?
