This amp uses Buzz 11's for the outputs.. Is there a good sub that will work??
M mike49504 Member Joined 2006 2011-11-14 2:12 pm #1 2011-11-14 2:12 pm #1 This amp uses Buzz 11's for the outputs.. Is there a good sub that will work?? ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2011-11-14 8:57 pm #2 2011-11-14 8:57 pm #2 IRF540, IRF3415. ••• More options Share Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button.
