heatsink from alu profiles headphone amp
I will give it a shot...
Capacity is greatly determined by surface area.
If you rely on natural convection, then vertical surface area is what counts.
Using a tube profile, one of the two vertical surface areas is somewhat removed from the heat source. You will be better off using just a piece of 3-6mm think aluminum sheet/plate.
A rough guess for a 6 cm length of that tube profile is 15-20 W/K, if you a are dissipating around 10 W. (The thermal resistance goes up as you dissipate less).
Note that you need airflow - sufficient holes in the enclosure directly below and above the heat-sink. Or, better still, make the heat-sink do double duty as enclosure walls.
