diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Equivalent of transistors for http://www.borbelyaudio.com (http://www.diyaudio.com/forums/solid-state/19750-equivalent-transistors-http-www-borbelyaudio-com.html)
alex0 3rd September 2003 11:16 AM
I am interesting in a few schemes at this site: http://www.borbelyaudio.com .What sort of widespread transistors I can apply instead of J74BL, J79, J103, J148, K216, K246, K982 ?
AuroraB 3rd September 2003 02:06 PM
J74=2SJ74,- typical shorthand notation of japanese transistors leaves out the 2S- in front...
All the transistors you mention should be easily available, at least in western europe...
peranders 3rd September 2003 02:13 PM
You could test www.reichelt.de but you have to know a little german.
john curl 3rd September 2003 09:25 PM
Please don't waste your time trying to change the parts. They are not easily second sourced. Buy them from Borbely. They will be relatively expensive, but you are in no position to find them much cheaper. In fact, just get a 'kit' from Borbely, and don't waste your time trying to make it on the cheap. You will pay more, in the long run.
UrSv 4th September 2003 07:04 AM
Quote:
Why would it be so hard to find them cheaper? Borbely is anything from twice to 5 times the price of other sources.
alex0 4th September 2003 07:17 AM
Thanks all, especial AuroraB.
J=2sJ , K=2sk
john curl 5th September 2003 10:03 PM
AlexO, I did not note previously, that you live in Moscow. I understand now that the cost of these components is very high, especially from Erno, with the rate-of-exchange. I was trying to save others, who might live in Germany or many other places in Western Europe, to not waste their time trying to save a few Euros, but I will tell you the whole situation, in order to help you further.
We have used these devices, that Erno Borbely designs with, and sells, for many years. Once, I had 3000 2SJ79's in my possession along with the complement, the 2SK 216 (I think) . They were burned up in a firestorm, but if I had them today, I could sell them and buy a Porsche with the money. What used to cost 1 euro each, 20 years ago, now may now sell for many, many times more. When you are trying to buy just one to 5 parts, the cost of your purchase is always high, because of the handling cost for the distributor. After all, 1 piece, or 100, or 1000 pieces takes the same processing time. If you can find a cheap distributor, then you will have had better luck than I have, over the years. Give it a try, if you want.
Second, these devices are SOTA, which means the best available, like Porsche or Mercedes. These parts will always cost more than a near equivalent part that is not quite so unique. I cannot personally recommend other parts, because I do not use them, but there are somewhat similar parts available at a reasonable price.
bocka 10th September 2003 08:15 AM
Hi John, a Porsche or Mercedes seems to be very cheap in the States. The J79/K216 costs EUR 1,80 in Germany in quantities of 1000. For only $10000 a Porsche, not bad :cool:
You can get them also from Farnell, but the price is higher. Many parts you can get also from Heho if you are confirm with the German language.
john curl 11th September 2003 01:54 AM
You missed a digit on the price of a Porsche in the USA. ;-) If you can get these semis cheap in any other country, in small quantities, go for it.
Fred Dieckmann 11th September 2003 05:04 PM
Hitachi/RENESAS
http://www.ceitron.com/semi/semi.phtml?part=j79
http://www.ceitron.com/semi/semi.phtml?part=K216
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
