You may end up clipping the amp (not good). How efficient are your speakers? If it's below 95db, you may want to get something more efficient for TSE or keep it at lower volume level.and if i want it loud i have it at 5 o´clock..
Turning up the pot would be same thing as having lower value volume pot. It won't solve the issue you are having.
Hi all.
I've put in a 100 K alps volum pot in my TSE. Work well but i need to have the volum at 12 o´clock to hear anything.. and if i want it loud i have it at 5 o´clock..
Can i change the value of the pot so i don't need to have it so high? 50K? 25K?
Thanks //Daniel
A vol pot works by tapping off a portion of the full signal and sending it to your amp. A hi value pot at 12 o'clock taps of the same fraction as a low value pot at 12 o'clock, so this makes no difference in your case.
The problem that you are having is that either your source doesn't give off enough signal, or the amp has to low gain, or the speakers are very inefficient. You need to figure out which it is before you can select a solution to it.
jan didden
ok, thanks for your answers
I use my computer as a source.. I have an external usb sound card (BEHRINGER UCA222). Don't know if it give off enough signal..anybody know?
And i'm about to buy new speakers have looked at monitor audio (90dB/W) and AudioVector (91dB/W).. maybe to hard to drive?
Thanks //Daniel
Thanks //Daniel
Thanks //Daniel
Did you check to see if the vol control was wired in reverse?
If you have multimeter, measure the AC voltage at the analog output of the sound card when playing 1KHz sine wave and let us know.Don't know if it give off enough signal..anybody know?
Take a look at these brands.And i'm about to buy new speakers have looked at monitor audio (90dB/W) and AudioVector (91dB/W).. maybe to hard to drive?
Gedlee
Parker Audio
Ok, i'm at work now but i will measure it tonight.
If it was wired in reverse shouldn't max be at left (wrong way) then?
I'm not sure where my brain was when I suggested that, forget I said anything.
Slightly off-topic: is that avatar of yours a Hawk PAR radar?
jan didden
jan didden
That's the AN/FPS-35 radar at the former Montauk Air Force Station, now Camp Hero State Park, Montauk, New York.
- More Vendors...
- Tubelab
- value on volum pot?
