diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   Lm3886 passive bass boost (http://www.diyaudio.com/forums/chip-amps/188394-lm3886-passive-bass-boost.html)
lithoc 4th May 2011 09:59 AM
I found this site
LM3886 Gainclone 2x68 Watt Full Amplifier Project
Does anybody tried this circuit?
If we boost the bass on lm3886, does it affect the rest of the frequency band?
nightanole 21st May 2011 10:57 PM
Bass Boost Calculator
Might help with the math.
http://tangentsoft.net/audio/ppa/amp...schematic8.pdf
lithoc 23rd May 2011 06:36 AM
I've downloaded the Overture Design Guide xls file.
I'm trying to understand the negative feedback circuit.
Can someone elaborate the function of C3 & C4?
Which part of the circuit actually boosted the 30-70hz?
If let's say i need to boost higher(12db) and more bandwidth(30-100hz) , which component should I change?
Do I lower the gain by increasing the Ri to 2k ohm to get 12db+ bass boost?
According to the schematic, 30hz gain is 34db. From the design guide, I just do not get the correct value or something is missing in the circuit.
http://www.circuit-projects.com/cimg..._schematic.gif
Thanks in advance
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
