diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   Do I want fast settling or massive filtration in PS? (http://www.diyaudio.com/forums/power-supplies/186835-fast-settling-massive-filtration-ps.html)
Magz 11th April 2011 03:00 PM
Hello all,
I'm working on an upgraded power supply for my tube preamp (line and phono stages combined). It draws a total of 146mA, and is fully class A with a GZ33 rectifier and 350B tube shunt regulators. The current power supply uses a CLCRC filter with 33uF/10H (165ohm)/100uF/344ohm/66.7uF and I'm moving to a CLCLCRC design with something like 6.0uF/10H (36ohm)/47uF/10H (36 ohm)/100uF/300ohm/66.7uF. Transformer has ~75 ohms impedance.
I have been modeling this with PSUDII and have been able to obtain various configurations which pass the current step test (fast settling, no ringing). My questions is this - am I better off optimizing for fast setting time after a current step, or going instead for the most filtration (and thus lowest ripple) I can obtain? I can get the settling time to ~1/4 second for a 20mA step and about 30uV ripple, or get even lower ripple but have the settling time increase to almost 1/2 second. Does the presence of the tube regulators decrease the importance of the settling time?
Any help in this area is greatly appreciated!
Magz 11th April 2011 03:11 PM
By the way, the shunt regulator is located between the R and the last C on each channel. As PSUD has no provision for simulating this I did the sim without it just to look for potential issues.
jan.didden 11th April 2011 04:33 PM
Quote:
Originally Posted by Magz (http://www.diyaudio.com/forums/power-supplies/186835-fast-settling-massive-filtration-ps-post2534802.html#post2534802)
I assume that the shunt is in parallel with the load, at the very end of your CLCR etc, as is customary?
The shunt keeps the total current draw constant, which means that with an ideal shunt there is NO current step. So if you sim this without the shunt it gives a wrong picture.
jan didden
Vinylsavor 11th April 2011 04:45 PM
Your regulater at the end of the filter chain should make any changes in front of it mostly inaudible, if it works correctly.
Best regards ... Thomas
DF96 11th April 2011 05:00 PM
Provided there is no ringing, and the settling time is well below the LF limit of the amp, I'm not sure it matters. Adding a regulator makes it irrelevant anyway. The real issue is the stability of the whole thing including regulator.
I would go for minimum hum, consistent with no ringing.
Magz 11th April 2011 09:25 PM
Ok, so it seems that the consensus is that with the shunt regulator in the curcuit, I should go for the max capacitance and thus filtration that will remain stable, and not worry about making the settling time as fast as possible.
Thanks to all!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
