hello to everyone,
I am looking for at least 200w/8ohm power amplifier schematics. I have found many designs on the internet but i would like from you to suggest me a tested design. I will buid 6 channels for two tri-amp speakers. I found the aussie nxV300 interesting but he only sells it as kit whitch will be expensive for 6 channels.
Have a look at Rod Elliott's amplifiers.
Maybe you find one suitable.
Of course it would be easier if you look for 100w/8ohm.
The difference is only 3dB soundlevel between 200->100w.
Here is link to ESP Projects:
ESP Projects Pages - DIY Audio and Electronics
Apexaudio may have a good amplifier.
Here is a MOSFET with 240W into 8 Ohm:
http://www.diyaudio.com/forums/solid-state/162043-mosfet-amplifier-irfp240-irfp9240.html
