i need power supply for theses,
24v ac 1.5a
12v ac 2a
can anyone share link for a power supply for sale,
i have $18to spend but if need be...
i just purchased a tda7294 amp + ac-dc rectifier , with 6n11 buffer
ok i need help finding a good power supply, am a noob, so.. any help would be helpful
the seller suggested use AC24V (about 1A-1.5A),,,,, after rectifier the DC is 24V*1.414=+-34V
and 6N11 preamp use 12V (1.5A-2A)
tda amp specs
Input voltageDC ±25V--±38V
ac-dc rectifier specs
input voltage:Max AC 33V
pre specs
i have a transformer in parts box, 10.2-0-10.2 vac will this make the cut?, along with 12vac wall wart for pre?
any help is much appreciated.
24v ac 1.5a
12v ac 2a
tda amp specs
Output power:68W+68W
Output impedance:4-8ohm
Output voltage: ≈ Input voltage X 1.414
pre specs
Input Voltage: AC 12V
Input impedance: 1 M Ohm
Output impedance: > 5K Ohm
Input sensitivity: 0-5V
Gain:0dB
Frequency response: 10Hz - 60KHz +/- 0.25 dB
Total harmonic distortion: > 0.0025%
SNR > 100dB
24v ac 1.5a
12v ac 2a
An externally hosted image should be here but it was not working when we last tested it.An externally hosted image should be here but it was not working when we last tested it.An externally hosted image should be here but it was not working when we last tested it.
tda amp specs
Input voltageDC ±25V--±38VOutput power:68W+68WOutput impedance:4-8ohm
input voltage:Max AC 33VOutput voltage: ≈ Input voltage X 1.414
pre specs
Input impedance: 1 M OhmOutput impedance: > 5K OhmInput sensitivity: 0-5VGain:0dBFrequency response: 10Hz - 60KHz +/- 0.25 dBTotal harmonic distortion: > 0.0025%SNR > 100dB
looks to me like you need a 12v transformer for the buffer 1 amp should be fine.
for the amps, a 24-0-24 ( or 48vct) transformer - 2 to 4 amps ( at least). 18-018 up to 24-0-24 would be ok. The 0 is for the center tap. lookup center tap transformers to learn more.
I have this one for a chip amp -
Chia Yu Co Ltd
Input: 2 X 120Vac 50-60Hz 3" Dia X 1 1/2" Tall
Output 42Vct 21V- 0 - 21V 80VA
frm apexjr. miscellaneous.html
teh 12v buffer tranny can be had anywere - wall wart, old cd player, even radio shack sells them. alos check jameco for stuff.
good luck.
Jeff
